no spark 1996 plymouth voyager 3.0 motor - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-11-2012, 04:47 PM
I checked the coil i turned the key checked for volts OK one wire going to coil. Inspected wires ohm to cap ok no spark??
Old 02-12-2012, 06:10 AM
EOD Guy's Avatar
Seriously...... you need to provide more info.....Type/year of the motor,, Points or HEI, how did you check the coil? by turning on the key?
Old 02-12-2012, 03:22 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
Autozone offers wiring diagrams, testing and repair procedures for many production vehicles.
Go to www.autozone.com
You will need to register and create a password.
From the dropdown select the vehicle (new).
Select the category. Vehicle repair guides.
Next you will find listings of repair categories or chapters. Navigate to wiring diagrams, testing or repair procedures etc. Then select the desired item.
Check the cam and crank position sensors. They are often the problem.
vicrod
96 Plymouth Voyager spark problem? baddbob Electrical 12 05-19-2007 04:44 PM
1997 plymouth voyager vans tranny LXZ590 Transmission - Rearend 2 12-27-2006 03:45 PM
90 Plymouth Grand Voyager LE Cobra Transmission - Rearend 10 10-26-2004 06:21 AM
wiring cd stereo in 95 plymouth voyager skipper45mn Electrical 1 10-05-2004 03:29 PM
wiring cd stereo in 95 plymouth voyager skipper45mn Electrical 5 10-05-2004 03:27 PM
