Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - no spark?
Thread: no spark?
Old 03-20-2004, 06:28 PM
killerformula's Avatar
killerformula killerformula is offline
Last wiki edit: Carburetor
Last journal entry: Clean up
Wiki Edits: 3
make sure your 12 volt source to the distributor is giving you an honest 12 volts. DId you just hook the HEI up? Did you make sure the 12 volt source to your ignition isn't one that goes dead during the crank cycle of your motor?? I've seen it done before...
K
