No Spark, 454, TBI, 1988 GMC ck3500 - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-11-2010, 02:11 PM
The motor was running when I pulled it out. Rebuilt the engine, Reinstalled the eng. Now it will not start because it has no spark. I installed a new Distributor with the old coil I new was working. No spark, installed a new coil, No spark, Returned the Dist with another new one, No Spark. All new plugs, Cap, Rotor. Power to the coil but still no spark, fuel injectors work fine pwr to the oil press switch. Fues are good, the 20 amp fuse under the hood is ok, but no pwr to it?
I replaced the transmission before installing the engine, if this has anything to do with it. The eng turns over nice,fuel coming out of injectors, I can not get any spark out of the coil!!! this is a kick in the kiester for me. Any help would be very appreciated. Thanks, Paul
Old 11-11-2010, 03:07 PM
LATECH's Avatar
If the injectors are spraying then either the coil is bad or you forgot to put in a rotor. If you checked right off the coil wire then it has to be the coil. You did check all the grounds...didnt you?
Old 11-11-2010, 06:12 PM
No Spark,454,1988 gmc
No the coil is ok, tested and even repaced one. Reset every relay, and cannon plugs on the computer, and now I got Spark, is their a certain relay that could of hung up? Thanks for the reply. Paul
Old 11-11-2010, 06:24 PM
LATECH's Avatar
power goes straight through the ignition switch from the fuse link at the starter, but you said it had power.
Could be bad connections at the white wire on the coil (ground control side) or at the module end.
Old 11-12-2010, 10:25 AM
Thanks for the input, nice to get a fast response.
what type of trans in 1988 GMC Jimmy?? kuhn-77 Transmission - Rearend 1 09-26-2007 05:03 AM
Chevy 454 Spark Plugs Selection Help leejoy Engine 12 10-02-2006 12:05 AM
1988 GMC Suburban Seats. M&M CUSTOM Interior 6 03-05-2005 08:51 PM
1995 GMC No Spark 78Z Engine 1 01-24-2005 05:21 AM
454 tbi on a 350 intake??? dunegoon Engine 5 06-28-2004 06:26 AM
