NO SPARK !!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-20-2004, 09:56 AM
NO SPARK !!!
Hey Guys,
Have a question about a 1977 K10 Chevy with a inline 250 6 cylinder. I can't get any spark from the disturbuter I have 12volts going to the coil 12volt going in to the dist. at the module. I replaced everything coil, module, pick up coil, cap, rotor, condenser/capicator. This system has a remote coil, all grounds are good at least i think they are. I'm getting no spark can you help me. I hooked up another hei dist. from a V8 chevy with coil in cap ground off the valve cover and spin the shaft I get spark
HELP ME PLEASE
Old 12-20-2004, 10:17 AM
Last journal entry: The floor going in
if it has a balist resitor in the ignition system bridge across it and see what happens ?
i take it this systems has points in the distributor is the gap ok reduce the gap and see if you get a spark
Old 12-20-2004, 10:54 AM
poncho62's Avatar
Wiki Edits: 5
Is the gap for the pickup coil set right? It wasn't set right on my Dodge van and it had no spark. Set it and....voila......spark.
Old 12-20-2004, 10:58 AM
no point has module and is good took out of dist. taht worked
how do you set gap at pick up coil?
Old 12-20-2004, 11:02 AM
poncho62's Avatar
Wiki Edits: 5
The Dodge one had a slot where it was tightened down.....you set the gap with a feeler guage. Don't remember the setting.
Not sure how the Chevy one is, but probably similar. Someone here probably knows the setting..................
Old 12-20-2004, 11:11 AM
I dont think there is a way to adjust it, it set on the shaft and a c-clip holds it down no adjusting like that
Old 12-21-2004, 02:21 PM
No Spark!!!
The little washer under the disturbuter shaft what purpose does it do and would it have anything to do with not firing?
Old 12-23-2004, 08:24 AM
Never figured out the problem but i got it fixed put hei in cap coil in and it worked just fine
