no spark at coil - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-24-2012, 05:40 PM
Last journal entry: 1971 elcamino
no spark at coil
I have a 71 elecamino stock 350 stock distributor and points i let the car idle for 10-15 minuets it died i have no spark i have a dim light at the positive post on the coil.I checked the spark at the coil wire to ground about half inch away no spark 2nd coil,could i have fried my points any help thanks very much that dim light goes on when the key is on Dale
Old 03-24-2012, 05:54 PM
lg1969's Avatar
Google "Tunnel Ram 406"
Check the dwell it should be 30*-32*. Make sure you put a little grease on the rubbing block. Also check distributor shaft if it loose. You should read around 9 volts at the pos terminal of the coil when the switch is in the "on" position and 12V when you crank the motor.
Old 03-24-2012, 07:07 PM
S10 Racer's Avatar
http://www.warsprints.com
It could either be the points or the condenser. If you have tried two different coils, it fairly safe to say it's not the coil. Check with a voltmeter at the coil + post and make sure you have 9+ volts. If you don't, there is a problem with the wiring. You could "hotwire" it just to see if it will start. Just hook a wire direct from the + post of the battery to the + side of the coil. If it starts and runs, you will have to pull that wire to kill the engine.
Weak Spark off Coil!?? 11echo Electrical 16 03-01-2009 01:38 PM
blazer has spark at coil and gas no spark at plugs ricksautorestoration Engine 29 02-15-2007 08:30 AM
replaced coil still no spark off coil jackfrost51 Electrical 11 05-12-2004 12:19 AM
No spark from coil jmi Electrical 4 11-13-2003 02:37 AM
No Spark at Coil/ 350 SBC 1966impala Electrical 4 10-01-2003 12:07 PM
