No Spark - Duraspark - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-11-2006, 12:09 PM
I have a '65 Mustang with a 351W and a Duraspark/MSD ignition setup. In a previous post I said I thought I may have a charging problem, and it turns out I did. I took the alternator out and found that one of the brushes was broken. Easy fix. However, the car will not start. It died on me after a 900 mile road trip and has not started since. I bought a new Duraspark stator, and that did not work. I switched coils, that did not work. I switched ignition boxes (MSD 6A -> MSD Blaster that worked before), and that did not work. I changed components in every conceivable way to try to isolate the problem, but to no avail. I have run the Duraspark system with MSD components for years without a problem. I even isolated the tach thinking that may be an issue. I am totally stumped on this. I thought I knew everything about this old Mustang, but I guess not. HELP!!!!!! PLEASE!!!!
Old 07-11-2006, 12:21 PM
Wiki Edits: 31
are you running a duraspark box along with the msd? they were noted for failing.
Ignition system info................ poncho62 Electrical 18 10-11-2008 10:10 PM
MSD No Spark Canadian Charlie Electrical 3 04-14-2006 06:15 PM
3.0 taurus with intermittent spark fumplet Engine 0 03-04-2006 08:10 PM
try again slow spark jackfrost51 Electrical 2 09-08-2005 07:01 PM
Can't restart engine Weak spark? Ratchet Engine 4 06-19-2005 06:00 PM
