No Spark!!help!!!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-21-2004, 06:20 PM
Member at Large
No Spark!!help!!!!
The other day, I lost ignition spark while driving. I have a 72 big block with a HEI ignition. I replaced the control module, rotor cap and the coil. I still have no spark. I have proper voltage coming to the distributor. I don't know what else to do.....please help!!!!
Old 04-22-2004, 02:26 PM
poncho62's Avatar
Wiki Edits: 5
Get another distributer that you know works.Put your coil and cap on it. ........That will narrow it down....With the Chevy system, I can't see it being anything else, since you have 12 volts going to it.
On the Mopar distributer that I have in my van, the pickup for the module has to be set, just right....did you check the GM oickup.
Ontario Rodders
Old 04-22-2004, 02:36 PM
CurtisL's Avatar
Automotive tech.
before you jump to conclusions .. check everything.. did you check to see if mabee your timing chain busted? just a idea.. how many miles are on your vehicle.? proper diagnosing will save you lots of time and money.
Old 04-22-2004, 02:37 PM
poncho62's Avatar
Wiki Edits: 5
Goes without saying that you check that the distributer is turning.
Ontario Rodders
Old 04-22-2004, 05:57 PM
Member at Large
Well, the engine only has a about 200 miles. I think the problem is I put a 30 year old distributor back on.......the rotor does turn, so the timing chain should be ok........I assume.....Guess I'll cry in my soda and shell out the cash for a MSD.....Thanks everyone....
