No Spark No Fuel 305. Help Please - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-03-2011, 07:24 PM
My Trucked Stalled Today. Started Right Up Stall A Few Times On The Way To Auto Parts Store. Bought New Coil New Coil Wire. It Started Right Up No Miss. Ran Good All The Way Home ( 5 Miles).
Stalled In My Drive Way. I Am Going To Replace Ing Control Mod In Morning Along With Cap Rotor Wires And Plugs. I Have Fuel Pressure Up To The Throttle Body But None From Injectors. Any Help Would Be Greatly Appreciated. This Is My Work Truck And Need To Be On The Rode In 2 Days. 1987 Chevy Scottsdale With Unknown Year Motor Swap.
Old 03-03-2011, 07:42 PM
ignition module in the distributor is shot. if the computer doesn't see ignition pulses from it, it won't fire the injectors
Old 03-03-2011, 07:56 PM
Could There Be Any Other Issues I Should Consider? I Am Almost Ready To Buy A Newer Truck And Dont Want To Waste To Much Of My Savings Keeping This One On The Road. Not That I Have Much Choice Any Way But Want To Have All My Bases Covered.
Old 03-03-2011, 07:59 PM
chances are the module died. the module was working and cut out when it got hot.
happened to me before
Old 03-03-2011, 08:03 PM
Thanks. I Will Replace In Morning Along With Cap Rotor Plugs And Wires And Post Results.
Should I Worry About The Ecm Or Ignition On Colum?
Old 03-03-2011, 08:05 PM
ecm very rarely dies. you'd have more problems then just stalling if the ignition switch was screwed.
i wouldn't bother with the Cap Rotor Plugs And Wires unless they need changing anyways
Old 03-03-2011, 08:09 PM
I Have Had Ocasional Starting Problems. Turn Key Fuel Gage Maxed Wont Start. Somedays Happens All Day Somethimes Not For A Week Or So But Has Always Started Eventually. Usually After Two Or Three Tries. I Almost Suspect A Bad Ground But Am Clueless When It Comes To Wiring.thanks Again
Old 03-04-2011, 06:15 PM
Cape Cod Bob's Avatar
Having been down this road many times with daily drivers I would sink my money into a newer vehicle. One with a warrentee.
When they get old they need a lot of attention.
Old 03-04-2011, 06:42 PM
sbchevfreak's Avatar
Licenced Automotive Technician
Very common problem on this era GM HEI was cracked distributor reluctor, causing intermittant misfire, rough run, no start and stall, just to name a few. The only repair for that is a new dizzy...
Old 03-04-2011, 07:09 PM
Pulled The Ignition Control Module Today. Had Very Coroded Terminals. Got It Tested And Passed. I Cleaned Terminals With Some Emery Paper Replaced And Truck Fired Right Up.thanks For The Help.
fuel and spark but no start stroker444 Engine 12 05-23-2010 02:17 AM
Fuel (pressure) or Spark problem? Ignitrous Engine 1 03-19-2010 01:17 PM
Detonation- Spark or fuel Beenaway2long Engine 2 04-19-2005 07:26 AM
no spark or fuel 350 tbi? downhilleric Engine 5 12-09-2004 08:45 PM
TBI 350 no fuel or spark? downhilleric Introduce Yourself 1 12-07-2004 09:16 PM
