no spark replaced alot need help - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-29-2011, 07:50 AM
Hey everybody I got a really big issue and need some help. I have a 95good trans am with the optispark distributor also have msd box 6alask pn6420 and msd blaster coil...
I was at a stop light n my car died it was idling n just cut off n wouldn't start back up it cranks n nothing happens...so we began test n figured out that I had no spark from the optispark so knowing their failure rate I bought a new ac?cel one from JEGS and put it in yesterday and nothing still .....I have a noid light n tested the coil and it has spark I tested the coil wire to the optispark n I had spark but when I put the noid light on a plug it has nothing still any help is greatly appreciated thanks
Old 12-29-2011, 08:24 AM
bondo's Avatar
Ayuh,... If there's spark out of the coil, 'n into the distributer, then the cap, rotor, 'n plug wires, 'n plugs are all that's left, Downstream...
It's Got to be 1 of the above...
thanks alot jon scottnaidan Introduce Yourself 1 07-13-2010 07:42 PM
Alot of BS powerrodsmike Off-Topic 9 03-15-2008 08:48 PM
been away for awhile but Iam back now and I see alot of new names but dont see alot o lowgirl Introduce Yourself 3 02-23-2008 08:24 PM
Replaced Brushes & replaced battery terminals 78novaman Electrical 1 10-01-2006 07:39 PM
replaced coil still no spark off coil jackfrost51 Electrical 11 05-12-2004 12:19 AM
