Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - no spark at sparkplug
Old 09-23-2004, 05:01 PM
docvette's Avatar
docvette docvette is offline
Wiki Edits: 12
12 volts
Doc here
If you have 12 volts at the batt terminal on the HEI, Then no further testing is required there.
Test the ECM, Go to the local Parts store and have them test it for you.
If that's good, then the next step would be the Magnetic pickup.
If all else fails, replace the coil.
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
