yes u can adjust float level with car running, first start engine, second losten the screw with the jam nut on the top of the rear float bowl, third unscrew sight plug on side of float bowl (brass flat head screw) then play with adjusting screw and lock nut (losen nut then u can mess with the float level, tighten the screw and the float goes up, losten the screw and the float goes down if i remember properly) do this untill gasoline just dribbles out of the sight plug hole then tighten lock nut and replace sight plug
