No Spark Thunderbolt IV Igintion need help - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-10-2011, 01:03 PM
Dear all,
I have a Chevy G20 Van engine which I converted to a marine engine.
I had to add a Holley elctrical fuel pump and added all marine specific parts.
I have oil pressure measured with a gauge.
No I have a problem I have no spark.
The Ignition System was working fine before. I assume another error.
I have 12V on the positive coil terminal (+) which I bought brand new.
How do I test this unit?
Here some pictures
I have a white green & a white red cable comming out of the hall cell from the distributor. How to test the correct switching the hall to ground?
I painted the block and have a gasket between the block. Do I have a gound problem of the housing of the dizzy?
BR
Bob
Old 04-10-2011, 01:10 PM
LATECH's Avatar
Last journal entry: GTO Reproduction Hood
Originally Posted by monette999
Dear all,
BR
Bob
That would be where I would start. You can remove the holdown and clean the paint off of the spot where it touches the dizzy and the bolt and clean out the bolt hole. That should suffice.
Old 04-10-2011, 01:46 PM
Thank you. I will try this.
It that does not help what comes next?
Is the black box an amplifier. How can I test the hall & the amplifier?
BR Bob
Old 04-10-2011, 01:54 PM
LATECH's Avatar
Look in todays posts. I revived a thread for another guy here. Docvette wrote one article. Hard to beat that.
Spark plug wires jumping spark STATUTORY GRAPE Engine 4 10-04-2009 05:14 AM
Miller Thunderbolt 225 AC Welder Strictly Gravy Garage - Tools 15 02-17-2008 11:26 AM
blazer has spark at coil and gas no spark at plugs ricksautorestoration Engine 29 02-15-2007 08:30 AM
M/T 427 Ford Hemi-Bolt Fairlane Thunderbolt 1 of 11! Owned by Boyd Coddington Malibu73 Hotrodders' Lounge 5 01-27-2006 06:58 AM
spark plug getting little spark 72 chevy elcamino Electrical 1 10-19-2003 04:54 PM
