Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - No start
Thread: No start
Old 04-26-2013, 03:55 AM
EOD Guy's Avatar
EOD Guy EOD Guy is offline
I'm not understanding your last post...... My ground strap gets voltage.
What are you calling a ground strap?
How are you determining that it's getting voltage?
3rd test:
Take the jumper wire you hooked to the "S" terminal on the solenoid (and hooked to the purple wire at the NSS) and touch it to the pos post of the battery, the starter should spin.
If it doesn't spin, you have a bad ground cable (should be run from the neg post on the battery to the engine block) or
a bad pos cable (should be run from the pos post on the battery to the large stud on the starter solenoid)
Name:	chevy starter dia.jpg
