No Start Blues !!!!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-14-2007, 09:14 PM
HELP !!!!!! DOC OR ELECTRICAL MASTERS ... I NEED A SCHEMATIC FOR A 64 CHEVY 2 NOVA. THE BATTERY AND 4 POST SELENOID IS LOCATED IN THE TRUNK. I'M RUNNING A ZERO GUAGE WIRE FROM ONE SIDE OF THE SELENOID AND THE OTHER SIDE OF THE SELENOID TO THE POSITIVE SIDE OF THE BATTERY. MY IGNITION SWITCH, THE PURPLE WIRE, RUNNING IT TO THE SELENIOD S TERMINAL IN THE TRUNK. A NUMBER 8 WIRE TO THE ALTERNATOR WITH 30 AMP FUSE LINK. I TURN THE ENGINE OVER AND THE STARTER WANTS TO SPIN , WHINES BUT DOESNT TURN THE MOTOR OVER. I HAVE A HIGH TORQUE MINI STARTER 2 POST AND A SPADE. WHAT AM I DOING WRONG ? WIRED IT SEVERAL DIFFERENT WAYS BUT NO LUCK. I HAVE A GROUND FROM THE BATTERY THROUGH THE TRUNK PAN TO THE FRAME THAT IS SOLID SUB FRAME CONNECTORS A GROUND TO THE FRONT FRAME MARTZ CHASSIS TO THE ENGINE. PLEASE CAN SOMEONE SEND ME A SCHEMATIC ON HOW TO WIRE THIS ? OR GIVE ME ANY IDEAS ON WHAT IS WRONG ? ANY HELP WOULD BE GREAT. .' BOUT TO GO NUTS !!!! THANKS 64 CHEVY 2
"Basic of Basics" Welding - How do I repair body panels? Centerline Body - Exterior 33 03-31-2014 09:45 AM
crank no start meev182 Engine 7 06-17-2007 06:27 PM
chevy 350 won't start Troy Smedley Engine 2 03-23-2007 05:21 AM
My truck wont start. 91 serria 350 tbi montea Engine 17 12-17-2006 04:23 PM
caprice wont start? Brian Morency Engine 8 08-24-2004 11:37 PM
