No start and no compression - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-29-2013, 10:13 PM
engine got hot trying to limp it back home then slowly starting loosing power then shot off completely and wouldn't start, did some tests no compression at all on all cylinders, pressure coming out of oil fill cap when turned over drained oil too and hardly any oil came out so it burned some oil with it
Old 05-29-2013, 10:15 PM
vinniekq2's Avatar
what kind of car? timing belt?
Old 05-29-2013, 10:19 PM
99 chevy cavalier ha. 2.4 twin cam
Old 05-29-2013, 10:54 PM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
My experience with the Cavalier when they get hot is that the head cracks. Being a twin cam, most are "0" tolerance motors meaning if the timing belt broke, you may have some serious problems with bent valves.
Old 05-29-2013, 11:08 PM
before it shut down completely at idle it would make a ticking sound but higher rpms It would go away.
sbc 350 will start run rough for a few seconds die and wont start fuel-junky Engine 11 01-08-2013 11:30 AM
compression ratio compared to compression PSI squids1 Engine 14 12-28-2010 11:36 PM
Easy cold start, hard hot start dedub Engine 34 08-13-2008 05:21 PM
change modular car will start shut off and won't start back up Ramman Engine 1 11-26-2004 08:20 PM
Installed New Cam, CAR WONT Start/no Compression? sum87mustang Engine 4 10-27-2003 07:52 AM
