no start very weird!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-10-2009, 01:01 PM
ok pulled my car in to my garage wed night went to start it next moring carnked once then just clicked dead batt. putjmp pack on it one crank then click. then i noticed smoke coming from under dash wire from temp gauge gettin real hot temp guage didn't work so i just cut it. so then i go to put it in nutreal to push it really hard to get it out of park found out that the gear select cable is gettin hot to and melted it only gets hot when tryin to start i'm baffled any suggestions would be gratly appreciated thanx
Old 05-10-2009, 01:53 PM
woodz428's Avatar
Troll Hunter
Just a quick guess, but it sounds like the engine ground is bad and you are grounding through the body...that's why all the heat. I had a similar issue with an old Corvair that I had the engine out of and didn't reconnect the small engine grounds( there are more than one on a Corvair). I was setting at a red light , in gear with the clutche depressed and the clutch began engaging and a puff of smoke came from the tunnel where the harness lived. It had been grounding through the clutch cable and the cable ran in the same tunnel as the wiring...result was that I had to give it a quick extuingisher shot and repair the harness. I would guess a grounding issue.
Old 05-10-2009, 03:44 PM
302 Z28's Avatar
Yep, check your battery to engine ground, and your engine to frame grounds.
Vince
Old 05-11-2009, 10:22 AM
i relocated the battery to the trunk so the ground from engine to battery was gone so should i just run a ground from say the header bolt to the frame or any other suggestions would be appreciated thanx
Old 05-11-2009, 12:15 PM
streetrodderbn's Avatar
Certifiable Streetrodder
I normally deal with streetrods with trunk mounted batteries, I have had good success with running the neg terminal cable to the rear frame rail with a stud and star washer, then replicating the same setup in the engine compartment running from the frame rail to the starter bolt. I also have run welding cable from the neg. battery terminal directly to the starter bolt. I would shy away from using a header or exhaust manifold bolt due to heat issues that will surely melt the plastic coating on the cable Usually I ground the engine and body to the chassis also as a measure of safety(You can never have too many grounds!!)
Old 05-12-2009, 10:06 PM
Check the positive connections, too.
"Basic of Basics" Welding - How do I repair body panels? Centerline Body - Exterior 33 03-31-2014 09:45 AM
crank no start meev182 Engine 7 06-17-2007 06:27 PM
chevy 350 won't start Troy Smedley Engine 2 03-23-2007 05:21 AM
My truck wont start. 91 serria 350 tbi montea Engine 17 12-17-2006 04:23 PM
caprice wont start? Brian Morency Engine 8 08-24-2004 11:37 PM
