No Thermostat? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-04-2003, 05:10 PM
GearHead69's Avatar
'70 Chevelle '70 C10
No Thermostat?
Many racers don't even run a thermostat.. Why is this, and it seems to me that your engine would run a lot cooler with constant coolant flow rather than opening up at certain temps? What is the reason for not running one and can I do it with my Pro Street Chevelle? thanks
Old 10-04-2003, 05:38 PM
roys63's Avatar
What ever works best for your engine, i have had some that did fine with a 180 thermostat and the other liked a 160 and some liked none.
Old 10-04-2003, 06:17 PM
302 Z28's Avatar
Some vehicles can actually run hotter without a T-stat. The T-stat acts as a restriction actually slowing the flow down which allows more time through the radiator for heat transfer. You will have to try your application to see if this is the case.
Vince
Old 10-04-2003, 10:38 PM
lluciano77's Avatar
That is right. You should run a thermostat or at least the correct size restrictor. With nothing at all, the coolant can actually move to fast through your cooling system for the radiator to properly remove the heat. That is how cooling works in general. Cooling is the removal of heat. There is an optimum rate at which the coolant passing through the radiator can be cooled. Using different restrictor plates can tune for that.
I would run a thermostat instead because it does that and it allows for proper warm ups. Thermostats also have better maintenance of enigne temperature in changing conditions, (load on the engine, weather, gas quality, how well the car is running, etc.).
Old 10-05-2003, 05:58 AM
t stats
a thermostat is an important item in the cooling system
without one your warm up time suffers. maximum engine wear occurs during start up and the warm up phase as said earlier
it restricts the flow rate without one many old streeters over heat because the high flow of water stirs up the sediment and scale in the block and this gunk blocks those fine cooling tubes want it to run cooler try an oil cooler oil takes a lot of heat abuse in an engine. cooler oil equals longer engine life and oil life
how about water injection it will let you run more advance in your timming a bigger radiator more cores or a larger opening in the support pannel will help the trouble is it all costs bucks
how ever throwing that thermostat away may cost you more you can give it a try but me id give it some thought
Old 10-05-2003, 09:48 AM
GearHead69's Avatar
Ok I'll pick one up tomorrow, what temp should I get? Thanke
Old 10-05-2003, 09:52 AM
Vetter
I would say go for a 185* tstat. That is a good temp, usually.
78SilverShark
Old 10-05-2003, 07:51 PM
i like genuine
but test it in a boiling pan of water to make
sure it opens theres nothing worse than putting in
a crook one all that work and chasing your tail
its not offten but a newy can be faulty see ya
Old 10-05-2003, 08:03 PM
Dummiest thing you can do is run an engine without a thermostat. Period
Old 10-06-2003, 05:59 AM
roys63's Avatar
The Dummiest thing you can do is Run your mouth with out Thinking BUD!!!! I have a blower on a sbc and it comes up to running temp in 5 minutes and runs 180 deg down the highway with a out a Thermostat! Using a restricker. YOU must talking about a HONDA? MORRION! Check post # 162779
Choice of thermostat's depends on application and what works best with your set up not what your neighbor is using in his.
Old 10-06-2003, 06:01 AM
302 Z28's Avatar
Sounds like a cat fight brewing.
Vince
Old 10-06-2003, 07:39 AM
Dodge4fun's Avatar
Buttons, Why would you say something like that without telling everyone Why it is dumb?Share you wisdom, or are you just trying to Push everyones Buttons?
Old 10-06-2003, 09:15 AM
adryan16's Avatar
Engine Builder Mentee
Dummiest, I like that
