no turn signals - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-14-2005, 05:35 PM
no turn signals
Hi
Need help in finding out why I have no turn signals.I've got a 1971 ford f-250 pickup that recently has no turn signals. I've check the fuze and it's good. the bulbs are all new.I've got parking lights but when I flip on the turn signal lever I get nothing.The flasher is new and works in my other cars.Could it be the turn signal switch it self ? How do I go about checking to see if the switch is bad? Thanks Alot. ED
Old 12-14-2005, 05:57 PM
BOBCRMAN@aol.com's Avatar
Check for bad grounds at the light
Old 12-14-2005, 06:55 PM
302 Z28's Avatar
That year Ford is notorious for bad turn signal switches. I can't tell you how many I replaced when I was in the business. I think I still have a test switch in my tool box somewhere.
Vince
Old 12-14-2005, 07:11 PM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
do the brake lights burn?
how 'bout the 4 way flashers?
brake lights should be independent of turn single circuit
my 79 f250 's tail light sockets made that problem for me few years ago make sure to get the SHORT replacement sockets or the bulb will come through the lens
SR66
"SlowRide66"
"Illegitimis non carborundum"
Old 12-15-2005, 08:15 AM
no turn signals
Vince
Hi Vinny
Fasteddie here on the no turn signals on my 1971 ford F-250.I've got emergency flashers ,but when it comes to the left and right turn signals absolutely nothing.How does a guy go about testing the switch itself?As far as the other lights they all work. Brake lights , tail lights, parking lights,head lights.Sounds to me like its the switch .What about you? Thanks for your advice. Fast Eddie
Old 12-15-2005, 09:30 AM
Rob Keller's Avatar
Wiki Edits: 38
http://www.powerprobe.com/powerprobeproduct.html
this is a great tool for tracking power problems
Its a process of elimination
disconnect the battery and you will need a teat light and a jumper wire ( be careful with the jumper wire that you dont short something out )
there should be a plug around the steering column (maybe two)
disconnect it there and try the systems from there you should be able to get wiring schematics from here
http://www.fordification.com/siteindex.htm
& here
http://www.fordification.com/wiring.htm
if you can pick up a sued one from a bone yard(one that you know is working) you would be able to just plug it in .
BUT...
be advised even though it looks the same make sure all the wires go into the plug exactly like the old one .
if you find that the switch is bad then theres more to do ...
taking off the steering wheel and so forth...
let us know what you figure out
SR66
"SlowRide66"
Old 12-15-2005, 09:38 AM
switch
Sounds to me that the switch within the column is probably bad. This is from my experience with my '69 Cougar. I had similar problem. Granted the sequential taillights on my car are more complicated-- but I had the same symptoms.
A lot of times the contacts get corroded or melted/ wires get melted. A repro replacement for Mustangs and Cougars of this era cost around $80. Not sure if the same part is used in the F150 column. Assuming ford used the same in-column style switch, to replace the switch, you must pull the steering wheel.
But Before getting a new switch, I would also check the grounds in the turn signals themselves. They wont work if there isnt a good ground connection.
Old 12-15-2005, 08:11 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Check the 25 amp Fuse #6 first, Then check or just replace the flasher. Make sure you are dealing with the regular flasher and not the 4 way (which we know works) when testing..there are 2...
If the 4 ways, Brake and other lights are working, chances are you are dealing with a bad flasher or bad fuse as all run through the same switch...but if these check out then you will have to replace the switch.
Doc
Old 12-16-2005, 09:25 AM
DOC
Fast 1 here on the no turn signal lights.Every thing seems to check out ,the flasher is new the 14amp fuze in the fuze box for the turn signals is good,the bulbs are all new.I've got parking lights , brake lights ,tail lights backup lights and head lights but still no turn signal lights.One question for you.When I have the brake lights on and pull up or down on the turn signal arm the brake light goes out on one side or the other side depending on which way I pull up or down on the turn signal lever.Whats causing this to happen?Could it be the switch itself?With the steering wheel off is there any way to check out the switch with a test light?All your help is appreciated.Thanks again. Fast 1
Old 12-16-2005, 04:04 PM
302 Z28's Avatar
Replace the switch and be done with it.
Vince
Turn signals won't shut off after turning! 1meancuda Electrical 2 09-01-2004 01:48 PM
dash lights and turn signals - again SteveMach1 Electrical 2 12-13-2003 10:22 PM
Adding turn signals to '53 Ford P/U first timer Electrical 4 12-04-2003 04:37 AM
Wiring Tail Lights & Turn Signals horvath Electrical 15 04-30-2003 05:04 AM
turn signals impala dreaming Electrical 5 02-24-2003 06:29 PM
