no upshift - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-17-2007, 09:52 PM
Redman Racing
no upshift
This just started happening. I have a a4ld that i just had the bell-housing sent out to be milled flat and a new bushing center honed. Put in a new torque converter and everything went together great. Obviously filled the trans with new fluid, filter, gasket. Been driving it for a couple days and it has been working great. BUT THEN I started the truck and put it in D not OD as I always do for getting around my area and trans would not shift into second. I floored it and let off thinking maybe the Governor would unstuck ,well nothing. So I get to the next red light and I keep it in D and get to a particular speed where I know it would shift without a load and nothing. So I decided to put it in second and it work and stayed in second, figuring that it already shifted I put in back into D and it downshift back to first even without a load. Next i put it in OD and the trans shifts perfect. While I had the trans out I checked the vacuum line for fluid- nothing. I really can't come up with a idea of what happened. The fluid that was in the trans when I took it out was good clean nice smell, It seemed to be serviced before I got my hands on it. Any Thoughts?????
Old 02-18-2007, 08:17 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
year , make and model?
why was only the bell , converter dealt with?
what is the history of this trans? mileage, over haul at some point?
was the old filter opened up to look for debris?
GM 400/475 upshift problems coyote74 Transmission - Rearend 2 07-16-2006 05:47 AM
Delayed 1-2 Upshift, 95 Explorer 4R55E naturlm Transmission - Rearend 4 02-18-2005 08:38 AM
Tubro 350 no upshift 1962bobby Transmission - Rearend 2 01-09-2005 06:32 PM
700r4 no light throttle upshift 80SomethingZ28 Transmission - Rearend 3 02-06-2004 08:11 PM
700r4 upshift probs MDFbodies Transmission - Rearend 2 07-26-2003 10:24 PM
