no upshift on the pg - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-15-2005, 02:37 PM
powerglide tranny
I just put a 55 pg in a 56 chevy 210 four door. First gear works great but won't up shift to second gear. All other gears work fine it just won't up shift at all...Any suggestions.
Old 02-15-2005, 02:39 PM
sorry I posted this in the introduce yourself section as well. I just put a 55 pg in a 56 chevy 210 four door with a 265 v8, everything runs and works great except second gear I can't get the think to upshift. Any ideas or suggestions would be very helpful thanks.
Old 02-15-2005, 02:41 PM
poncho62's Avatar
Wiki Edits: 5
Modulator valve...?
Moving to tranny forum, you will get better results there.
Old 02-15-2005, 02:43 PM
have it in two places now tranny and rearend as well as introduce yourself
willys36@aol.com's Avatar
Wiki Edits: 21
Welcome. Being new to the site, you need to be sure to read the "Read Me' posts at the beginning of each forum. The ones here for example recommend that you just post a general introduction here and post tech questions in the appropriate tech forum. This will give you the best chance for a good answer.
Old 02-15-2005, 02:44 PM
Wiki Edits: 21
That happened to my wife's '56 w/ cast iron PG and it turned out to be a broken rotor in the rear pump.
Old 02-15-2005, 02:46 PM
how much of a pain is it to fix, i am new to the pgs and don't know my way around it at all. wich side is it on and all that please and thank you. And thanks for the fast replies
Old 02-16-2005, 04:22 AM
M&M CUSTOM's Avatar
Wiki Edits: 9
I merged two of your seperate threads on this same subject once others moved them here to Transmission/Rearend Forum.
Old 02-16-2005, 07:58 AM
Wiki Edits: 21
This isn't an in-the-car easy fix; requires a complete tear-down of the tranny to get access to the pump.
Old 02-18-2005, 10:07 AM
nigelh's Avatar
New Member
On mine all the clutches were burnt out.Had to have a complete rebuild including new torque convertor.If you get chance can you look at the colour of the trans fluid.I drained mine and metal particles came out with it, that was when I knew it wasn't good.Now I have lost the rod that goes from the box to the reaction arm.
Good luck with your problem at least you are in USA and can get the bits easier than I could.
