NO VACCUM, how to make it work? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-28-2006, 10:53 AM
Augusto's Avatar
From the middle of the world
Last wiki edit: How to rebuild an engine Last photo:
the diesel engine I swapped in has no useful vaccum to make the modulator work in the TH350 I installed, how can I make the tranny work rigth?, I tried finding a B&M modulink but seems like it is discontinued, any sugestions?
I added weigth to the governor and works fine, the diesel engine has much lower speeds than the gas units, the kickdown still gives me trouble because of linkage geometry but no big deal.
the vaccum for the modulator is what really is causing trouble, what can I do?
how are the supercharged engines doing this task?
thanks.
Augusto.
P.S. how does 31 mpg sounds to you for a daily driver C1500 pickup? this is what this truck is making with the diesel conversion. diesel fuel cost $ 1.02 per galon here.
Old 06-29-2006, 03:55 PM
use a vacuum pump with a regulator on the throttle linkage such as gm and ford used on older diesels, all it did was allow higher vac at low throttle pressure ,less at wider openings using a mechanicaly driven pump.Think of it as a tps for older diesels. Only instead of controling current it controlled vac.
Old 06-29-2006, 05:22 PM
Wiki Edits: 31
scavange junkyards for a '80-'84 Mercedes Benz 300D, in the rear they have auxilery electric vacume pumps that when new can obtain 30 HG, more than what u need. no diesel engine makes any kind of vacume. I'd be concerned also if u have a vac brake booster, need at least 13 HG to make them work right, if ya got a hydraboost, that's a diffrent story.
Old 06-29-2006, 06:50 PM
Augusto's Avatar
the alternator has a built in vaccum pump, I'm using it to make the brake booster work, sucks pretty hard, also I have a line connected to the modulator but it has a tee with a small air bleed ( carb jet ) and a plastic gas filter to prevent dirt from going to the pump, this makes the tranny work in a so so fixed manner, maybe half vaccum reachin the modulator, have not measured how much, it is not correct but works, with full vaccum it shifts rigth after taking off, with no vaccum it will not upshift at all, the diesel motor only goes up to 4.000 rpm.
I like the idea of using a valve connected to the throttle, maybe a regular petcock connected to the throttle acting just like a carb's butterfly, this placed instead of the jet, I'm sure it will work, will post later results.
any other tougths?
thanks for helping.
Augusto.
porting 882s at home,no machine work, rebuild, will it work? what are they capable of Warrant Engine 6 12-27-2005 01:14 AM
Good Grounding can make a difference ep33510 Electrical 2 12-07-2005 08:42 PM
did i make a mistake? akm Hotrodders' Lounge 15 03-04-2004 11:19 PM
will this work on the street?? deuce_454 Engine 19 06-29-2003 03:33 PM
I have a confession to make....... 454impala69 Transmission - Rearend 4 05-06-2002 05:19 PM
