No vacuum signal from carb - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-22-2013, 01:17 PM
The engine is a freshly built and broken in olds 403. the carb is the original 800 CFM Quadrajet, rebuilt by everday performance.
My problem is that i'm hooking my vac gauge to ports on the front of the carb but i'm not getting any signal at idle, it sits at 0 on the gauge. when i rev it up the signal bounces up to around 15. I've tried a few different ports with the same results, they can't all be ported/switched sources of vacuum are they?
I have my vacuum advance hooked to a manifold source of vacc, when i head back to the garage i'm going to try taking a reading directly from the manifold.
I just re-lashed the valves again, i thought i might have had them set wrong but it didn't seem like it. I use the preload method that comp cams recommended i do. tighten to 0 lash, then + 1/2 turn. One of the notes with my cam was tighter lash.
Old 06-22-2013, 04:05 PM
Ok the ports i was trying to pull a reading from are ported, problem solved.
Old 06-22-2013, 09:08 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Depending on the year, one of the vacuum ports could have been for the EGR. Similar in some ways to a ported source, but not quite. These cause trouble when used for the vacuum advance.
Old 07-10-2013, 12:00 AM
this helps explain the ports a little better
http://home.comcast.net/~kc8oye/Engine/ported_vac.jpg
Vacuum at carb Russgolfs Hotrodding Basics 1 12-11-2010 07:06 PM
Sufficient EGR vacuum signal? Sixshooter Engine 1 12-17-2005 03:24 PM
how much carb vacuum? Rubberman2003 Engine 7 09-20-2003 01:13 PM
carb vacuum MonteCrl Engine 1 09-26-2002 08:25 AM
Turbo 350 Trans Vacuum Signal? 54 Chevy Transmission - Rearend 2 07-22-2002 04:33 PM
