nocking noise 327 - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-28-2003, 08:42 AM
Question nocking noise 327
hi i have a 65 chevy with a 327.i put in a new cam and lifters and springs and its still nocking i cant seem to figure out were the noise is at it seems like it under the manifold not in the value covers.anyone mite know what the noise is? also i just got a timming light.i have my timming around 12 but.. i dont get these light it depends on the angel u look at the timing mark move your head just a little and it goes from 8 to 12.how do u do these correctly.thanks for the help of whoever responeds
Old 04-28-2003, 09:11 AM
New Member
Post
i had a knocking noise on my 350sb under the intake, and what it appeared to be was a lifter had failed after about 80k miles on it, but yours are new so you might have your valves adjusted incorrectly.....just a thought, good luck..
Old 04-28-2003, 11:31 AM
aroldfut's Avatar
New Member
Post
I had a similar 'knock' on a small block once and it turned out to be the fuel pump. You might want to check the pump and the drive rod to see if there is excessive wear.
Old 04-28-2003, 12:11 PM
Post
hi MATE,do yo get the knockin when you rev up?
or just when tickin over?
I had a tickin/knockin on a Chevy Caprice,at tick over,when i revved the engine the tickin went.
turned out to be a hydraulic lifter had a bit of crap in it!motor still ran strong tho.
MY DAD ALWAYS SAID"IF YOU"VE GOT A QUIET ENGINE,YOU GOT TROUBLE ON THE WAY! <img src="graemlins/mwink.gif" border="0" alt="[mwink]" />
Old 04-28-2003, 05:20 PM
Bartman39's Avatar
Post
If it has forged pistons then it may just be the reg knock or rattle sound of a little slop in the bore`s... If its cast pistons the its possible you have knocked a skirt off one of them...? There is a lot of difference between a knock and a tap...
Also if its forged pistons when its cold it will be worse but as temps come up it should become somewhat less...
[ April 28, 2003: Message edited by: Bartman39 ]</p>
