noise - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-17-2005, 11:06 AM
razorcd's Avatar
noise
those good ole engine noises...olds 350 roughly early 70's with now HEI ignition and edelbrock 750 carb. I have a lunati cam and lifters set new tim ing chain and gears. I know i have to identify exactly where it is coming from just want some pointers. It sounds like bottom end but not sure. I noticed some play in the crank pulley when I was changing the power steering pump pulley I just happen to grab the crank pulley and it moves up and down a bit more then it should if it should at all. The engine seem to run ok power is there oil pressure has dropped off a little at warm idle to about 32 when it used to be 36. Thats why i suspect maybe something going on in the bottom end the noise isn't always present or at least i don't notice it but at a low idle. cold or hot engine. its hard to tell with headers and hearing anything but exhaust.
Old 09-17-2005, 12:02 PM
DoubleVision's Avatar
there should be no play in the crank period that you can feel, was the oil pressure reading at idle? if not what is the pressure at idle? Are you sure the pulley itself isn`t loose? or perhaps the balancer? if the balancer has came loose it wollows out the keyway and the balancer, it makes it sound like it`s knocking. if the balancer and pulley are okay I would look further, usually if the main bearings were so loose you could move the crank the engine wouldn`t have enough oil pressure to live long. If this is a high mileage engine then it maybe time for a rebuild before it self destructs.
Old 09-18-2005, 03:35 PM
razorcd's Avatar
noises
The oil pressure is in drive when its around 32 after it been driven a few miles and warms. Its like 50 at start up. I haven't tore into yet I am hoping its just the balancer and no damage it seems to run ok that why I am hoping it just the balancer.
Old 09-22-2005, 10:48 PM
razorcd's Avatar
noise found
well it turns out i had a bolt backing out on the torque converter tightned it noise hasn't been heard so far.
Knocking noise, HELP! Please!! fireforsin Engine 4 01-04-2004 12:31 PM
My 231ci Makes Noise When I Accelerate 7skylark6 Engine 18 12-28-2003 10:53 PM
350 Tranny noise, not sure what it is... Juicer Transmission - Rearend 3 10-07-2003 10:39 PM
valvetrain gurus: need help identifying mysterious valve noise blndweasel Engine 10 03-04-2003 08:59 PM
th-350 clanking noise then grinding the nothing roadrash9r Transmission - Rearend 8 12-09-2002 04:32 PM
