Noise in Jeep front end - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-09-2010, 11:26 AM
I can't seem to locate the problem. I have a 96 Jeep Cherokee 4.0 fwd. I have a noise in the front end that sounds like its coming from the left side. Whenever I turn the wheel left I hear it , when I turn right it goes away. I thought it was a hub bearing so I replaced that , but thats not it either. I am baffled , if anyone has a opinion , I would like to hear it. Thanks
Old 08-09-2010, 11:38 AM
27 t's Avatar
WHO WHAT ME WAIT I DON'T KNOW.
Last journal entry: Door skins removed
whats the noise sound like ?
Old 08-09-2010, 11:41 AM
Jeep noise
It sounds like a muffled grinding noise
Old 08-09-2010, 11:49 AM
27 t's Avatar
if the noise is less when you turn right than its the right bearing thats bad
Old 08-09-2010, 11:55 AM
OK Thanks
I will pull a wheel and check it out
Old 08-09-2010, 02:43 PM
jeep noise
Yep... it is the right front hub bearing. replacing it now. Thanks
Old 08-09-2010, 03:02 PM
27 t's Avatar
no problem have fun...
Camaro front end swap help Augusto Suspension - Brakes - Steering 9 09-28-2007 09:17 PM
Front end mock up shows some problems, cut n weld or frame shop? Ripped Body - Exterior 9 11-26-2005 08:03 PM
Ford 9 inch rear end... whinning noise??? bg Transmission - Rearend 5 09-28-2005 02:03 PM
Got 39 Poncho, have front end questions rwruther Suspension - Brakes - Steering 0 05-23-2004 03:32 PM
Mustang II front end Question horvath Suspension - Brakes - Steering 35 03-02-2003 05:08 PM
