noises in the torque converter area. - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-25-2013, 06:04 PM
helrazr3's Avatar
im on a highway to hell
Last journal entry: new wheels and seats
hello all, when it comes to transmissions and torque converters my knowledge is very limited i dont really know their internal workings at all. as for the technical stuff its a 1986 chevy 350 motor a th350 transmission (bought at a swap meet) the torque converter is a b&m torque master 2400 i bought from classic ind. my original motor was a 327 with about twice the hp of the present motor but thats another story.the car its in is a 66 impala.
basically right now i have a noise that is coming from the rear of the motor or the bellhousing area it is loudest under the car at the torque converter. the best way to describe the noise is when sitting in the car it sounds like a diesel motor running at idle when driving the car over 50mph it gets a lot louder. but the trans. doesn't slip and it seems to shift ok the fluid is red and full. i checked the flywheel to make sure there were no cracks.
one question i had is this does the tranny fluid flow back and forth from the converter into the tranny ? when i orriginally filled it with fluid it was v e r y slow to flow in and i think i put more than a quart in but i assumed it would fill from the transmission once it was all running was i wrong? any suggestions are aprieciated
thanks rich.
Old 10-25-2013, 07:15 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Oil constantly circulates in & out of the converter as the engine runs.
I edited the thread title , since cutesy thread titles do not give the membership an idea of your questions
Old 10-25-2013, 07:50 PM
ProStreetRob's Avatar
5.7L S10 LS SS
I can tell you from personal experience a hair line crack (or cracks) in your flywheel will give you a sound very close to a spun bearing. A rattling, snarling, "diesel like" sound. Get under there and take a good look at your flywheel
Old 10-25-2013, 07:55 PM
helrazr3's Avatar
i did have that happen once a few years back and this is a different sound like a harsh wurring sound the flywheel was more like a clack clack rattle.
Old 10-25-2013, 08:17 PM
helrazr3's Avatar
no it stays the same but over all it has gotten louder since i first noticed it
Old 10-26-2013, 08:25 AM
Banned
clacking sound to me is a loose flywheel. check those botls
4l60e torque converter clutch torque capacity rx191 Transmission - Rearend 1 04-05-2011 05:03 AM
Torque Converter to Flexplate Torque Spec. Needed - 2004R Zeeb Transmission - Rearend 1 05-26-2010 07:47 AM
torque converter help lowandloud91 Transmission - Rearend 13 02-10-2010 11:37 AM
Bellhousing bolts and torque converter bolts torque specs Davey3ch Transmission - Rearend 2 09-04-2009 12:05 PM
B&M Torkmaster 2400 rpm stall converter vs. stock torque converter??? zbhover Transmission - Rearend 2 11-02-2008 08:52 PM
