noisey timing gear drive needs grinding - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-21-2011, 04:46 AM
MAKE EM STICK AND E.T'S QUICK
i just bought a dual idler noisey timing gear drive for my 327. i installed the cam, thrust bearing, cam and crank gears, and the cam "button". but i have to grind the cam button to clear the timing cover a lil and i have to grind the power idler axle on the block side. does anyone have any tips for me not to grind to much off.
Old 01-21-2011, 07:40 AM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
maybe different cover?
Old 01-21-2011, 07:45 AM
the cover would solve the cam button but there needs to be .005 to .075 clearance from the axle to the block to keep it from binding
Old 01-21-2011, 08:19 AM
delawarebill's Avatar
timing cover
a 2pc cover should do the trick... and if it turns out u don't like the gears, u don't need to drop the oil pan to change them the next time.... well worth the $40 bucks... bill
gear drive timing set sexypizzaman Engine 4 10-18-2009 09:21 PM
Gear Drive to Timing Cover Clearance Double_v23 Engine 5 01-11-2008 11:08 AM
Gear Drive to Timing Cover Clearance Double_v23 Engine 7 01-10-2008 07:12 AM
Gear-Drive Timing Set vs. Chain-Drive Timing Set nightrain_rod Engine 8 12-25-2003 03:36 PM
Swapping Gear Drive Out for Timing Chain or Belt Drive - Need Suggestions horvath Engine 4 05-24-2003 08:47 PM
