Noisy dry sump pump - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-08-2002, 12:02 AM
Post Noisy dry sump pump
My Moroso dry sump pump has started to make a really loud buzzing noise at about 4000rpm. The oil pressure reaches about 85psi, I assume the relief value is set at the factory setting of 50psi. The valve looks in good order. Has anybody experienced this before? The pump is fitted to a blown Chevy small block.
Any help would be appreciated
Julian.
Old 09-08-2002, 08:28 AM
4 Jaw Chuck's Avatar
Post
Are the mounts and belt tight? Extreme vibration can "fool" the relief vavle into opening at a higher pressure. Since the opening pressure is so high have you thought about replacing it? Is it adjustable?
— Han Solo
Old 09-08-2002, 10:52 AM
deuce_454's Avatar
Post
there is nothing in a hydraulic relief valve/ball system that will make a noise loud enough to be audible when boltet to a blown small block, What you are propably hearing is the pump cavitating/pumping small gas boubles. my bet is that the suction side is either restricted in some way causing cavitation, or the hoze from where you are sucking the oil is above fluid level at the given rpm..
thats just my 0.02$ worth
[ September 08, 2002: Message edited by: deuce_454 ]</p>
