noisy hyd roller lifters - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 05-12-2008, 12:32 PM
Cool...one more time...I will do that tonight...I just hope that its just valve train noise and not a bearing going out...
  #17 (permalink)
Old 05-12-2008, 12:46 PM
Mine were somewhat noisy in my SBC too ... ( GM " Hot cam " )
Factory GM hydraulic rollers with factory 1.6 roller rockers ... I have a cut out valve cover that I install. After the engine is warmed up to normal operating temperature ... I install the cut valve cover and then adjust the valve with the engine running. Back one off until it clicks noticeably and then tighten until the noise decreases. Then 1/2 a turn more ... lock down the adjuster and go to the next one After doing all 16 ... mine is noticeably quieter ...
Worked for me
  #18 (permalink)
Old 05-12-2008, 01:57 PM
Jmark's Avatar
also, when you have the covers off tonight, look them over inside real good. Big roller rockers can rub if the VC is off just a tad. If you see any shiny marks on the inside of the covers, you may have found the noise.
Mark
  #19 (permalink)
Old 05-13-2008, 12:24 PM
got home after work and readjusted lifters..
set to TDC and adjusted and followed the procedure below
http://www.thedirtforum.com/chevyvalves.htm
I did a 3/4 turn and locked them down.
When the procedure was complete it helped a little But I think they are still
very noisy more than I would like..
Are there after market roller lifters made that are quite.?
The ones I have are GM OEM roller lifters....
  #20 (permalink)
Old 05-13-2008, 12:30 PM
Why NOT adjust with the engine running??
You are relying on marks, mirrors and smoke the way you are doing it IMHO ...
Cut yourself a valve cover and do it right ...
  #21 (permalink)
Old 05-13-2008, 12:41 PM
working on gettin an old valve cover now...
  #22 (permalink)
Old 05-13-2008, 03:08 PM
Jmark's Avatar
I used to adjust them with the engine running. Not any more. It's just too messy for me. Plus, if you have full roller rockers, you won't be able to put a stock cover over them, unless you cut off the whole top. I have a stock SBC cover with the top cut out and it still hits. If I cut any more, i'll have oil spraying everywhere. I've had zero problems adjusting them the "new way"! LOL
Here is the link from above, I could not get it to work as posted.
Mark
  #23 (permalink)
Old 05-13-2008, 03:17 PM
Double_v23's Avatar
Horsepower Enthusiast
Last journal entry: Finished BMOD001FH
I never adjust them with the motor running and often times I set our race motors up with a dial indicator. These have special hydraulic lifters and need to be set at .002-.004 preload.
Hyd. Roller lifters on Solid roller cam danrace1 Engine 6 01-28-2010 05:21 PM
GM hyd roller lifters and .540 lift GMC boogie Engine 4 01-30-2008 11:51 PM
Hyd. Roller lifters problems hotrodf1 Engine 121 10-25-2007 01:31 PM
Hyd Roller lifters underdog305 Engine 7 10-13-2006 08:42 PM
Roller Lifters - standard cam ckucia Engine 27 01-27-2006 01:05 PM
