noisy hyd roller lifters
Just a quick question....
How noisy are roller hyd lifters suppose to be...Fresh 383 about 1300 miles on new motor
They seem to clatter at about 1800-2200 rpm I have set them and reset them 3 times they still seem to be noisey....is there something wrong..?
SPECS=
1965 el Camino
383 4 bolt main roller block 30 over
Bore & hone with torque plate
RPM 4130 forged steel crank
Clevite rod bearings CB663P-8-000
Clevite main bearings MS909p-000
KB prem forged CNC pistons 3.75 X 6.000 X 5cc flat tops
H beam 6" 4340 rods
Dart Pro1 215 heads 64cc angle plugs 205/160
Comp Cam XE288HR Hyd roller cam Duration@50 236/242 LS110
GM 2148 Hyd roller lifters
Comp Cam pro 1.6 Magnum roller rockers
Air Gap intake
Demon 750
700r4 w/2900 stall
posi 373 gears
Dyno 502hp at 6400 / 464tq at 5100 to the flywheel
