Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - noisy hyd roller lifters
Old 05-12-2008, 12:31 PM
C-10's Avatar
C-10 C-10 is offline
Revolution Calling
Last journal entry: Poverty caps live on.
Yes great vid. Great sounding small block. Personally, the light valve train noise wouldn't bother me. Although I am used to mechanical rollers... .
I bet your valve covers are exaggerating the noise some. Sounds crazy but try a different pair before you resort to drastic measures.
Other than that, double check your lifter preload. The Comp hyd. roller lifters I have spec .030" of plunger preload, which happens to be a half-turn at the rocker with a 7/16 stud. I don't know what GM specs on theirs as far as preload.
