noisy hydraulic roller - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-18-2009, 09:55 PM
Hi all,
I'm having issues quieting lifter noise on a retro hyd. roller 383. I have a question regarding hyd. lifters (most all my experience is with solid). I adjusted the lash to 0 +1/2 turn. Warmed engine (the warmer, the noisier) and let cool. I removed the valve covers and I can physically push on the pushrod side of the rocker (int. #5) and collapse the lifter. Without visually seeing damage, what else could be going on? Is there a spec. for lifter bore clearance? If this clearance is too great, would this cause the lifter to "bleed off"? Without measuring the clearance, I would guess it to be about .005". It doesn't appear to be much different than the rest, visually.
The lifters are Edelbrock Retro Hyd. Rollers.
Any professional input would be appreciated.
Old 08-19-2009, 11:39 AM
Last journal entry: PICTURE TEST
lifters
The blead off of the lifter is controled by the internal's of the lifter, not the lifter body to bore clearance.
Noisy lifters is a very, very subjective deal. All the Hyd rollers that i have worked on (retro, not stock) have had what most consider to be noise. They are not sewing machine quiet like there flat tappet brothers. You have the tie bars in there moving around, the lobe deisgn is different, lifter weight, etc.
How are you adjusting the pre-load, Engine running or static?? If you are static adjusting them are you using the IC/EO method???
Have you tried backing off to 1/4 turn pre-load???
Again if you are compairing this cam to a flat tappet hyd it will have some more noise.
Keith
Old 08-19-2009, 12:40 PM
K-star,
Thanks for replying. Trust me when I say "it's noisy". Embarrassingly noisy.
I've been all over the board with adjustment (static, running, 1/4 turn, 3/4 turn, etc., etc.). I am using the IC/EO method. I mentioned that the #5 INT. lifter is "compressible" when I push on the rocker arm, where the others are not. Is it possible for that lifter to be faulty or damaged without visually appearing to be? Is it possible that the oil passage that feeds that lifter is plugged? Maybe, I should swap that pair of lifters with another cylinder to confirm or rule that out? Thanks for the help.
Jeff
Old 08-19-2009, 08:08 PM
lifters
Do you think all 16 are noisy?? Or just one lifter???
I have only ever used one set of Edelbrock retro hyd rollers. If i remember right i think they are made my Morel. Morel are one of the better lifters out there, but i did have issues with a set of them a few years back. The set i had was off the hook loud when cold but reasonable when warm
Keith
Old 08-19-2009, 08:47 PM
SS66chevelle's Avatar
HR VIOLATION
Keith
my thoughts exactly. if it's just one lifter perhaps it's bad? since its a hyd roller I dont think it would be a problem if you took one off another cyl. just to test it at idle (ex: if the #1 is noisy swap it over to the other side of the motor and see what happens) before everyone jumps on me, I realize you shouldn't do this with a flat tappet cam due to wear patterns but I dont think it would be too bad on a roller, especially if you do it for a short time at idle.
Old 08-20-2009, 07:53 AM
Keith
Well... Like you said before, they are not "sewing machine" quiet. It is definitely one or two that are the problem. I didn't get a chance to tinker with it last night, hope to tonight. If what you say about Edelbrock/Morel manufacturing the lifters is correct, I would say they should be a quality product. I'm going to call Edelbrock and see what they have to say.
Old 08-20-2009, 07:59 AM
Thanks for the reply, SS66. I agree with you about swapping roller components. It's not the same issues as flat tappets. Swapped them from motor to motor, cam to cam, etc. for years with no issues. Those were solid rollers, albeit.
Edelbrock Performer RPM Hydraulic Roller Regal Beagle Engine 56 12-31-2008 05:30 PM
hydraulic roller noise al37ford Engine 11 08-29-2005 10:19 PM
hydraulic roller retro fit question ko.17 Engine 5 06-22-2005 04:32 PM
Big Car - Hydraulic Roller Vista Cruiser Engine 2 05-14-2005 01:06 AM
Hydraulic lifter question + 1.6 roller rocker 59vette Engine 2 10-27-2003 12:13 PM
