noisy lifters - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-23-2002, 06:56 PM
Post noisy lifters
When ever I start my 1996 Dodge V6, The lifters clatter until the oil pressure comes up, 3 to 5 seconds. What is causing this. I was under the impression that the oil filter had a check valve in it to prevent this. I have changed the filter tree times since this started. If the lifters don't have any oil pressure, I am sure the main and rod bearings are suffering also.
Old 09-23-2002, 08:23 PM
drgnwgn289's Avatar
Post
I don't know much about hydraulic lifters since none of my engines have them, but I think that is normal until they pump up....
Old 09-23-2002, 09:13 PM
BstMech's Avatar
NYOFP4RJ3CHRIS
Post
How many miles does it have? Did it start doing this all of a sudden? It might be time for a little heavier weight oil.
