noisy roller rocker or lifter? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-22-2007, 02:55 PM
I have full roller rockers and they are noisy. Sounds like they are slightly out of adjustment tapping. It runs fine and I have adjusted at lest 15 times. Hot cold from 1/2 to 3/4 sound about the same. They are 1.5 trickflow on a hydro flat cam. Is it a dad lifter. Sound louder on one side but hard to tell. I am thinking of replacing with crane or comp in a 1.6. I have another post on that.
Old 12-22-2007, 03:25 PM
I have the 1.6 full rollers in my ZZ430. They have a reputation for being noisy. They deserve it ... Mine are factory OEM Chevrolet ones ... roller rockers are just noiser than the stamped everyday sheet metal rockers.
I have found that a stud girdle helps keep the roller rockers in better adjustment and also helps reduce the noise.
Old 12-22-2007, 04:03 PM
Jmark's Avatar
My sons 400 has a full roller setup and sounds like an old Singer sewing machine. Been told many times it's normal and not to worry about it, so we don't! LOL
Mark
Old 12-22-2007, 04:37 PM
454 Rattler's Avatar
NEVER SATISFIED !!
I used steel-tipped roller rockers on my 454. They sounded like I had solid lifters. (I didn't)
I never got used to the noise.
I think that Deuce is probably correct.
454 RATTLER
Old 12-22-2007, 06:47 PM
454 RATTLER
Is that how you got your user name ?
Shane
Old 12-22-2007, 06:57 PM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
Try adjusting them on the "ramp" just after the back side of the lobe. I have found several cam grinds that have had more clearance there then on the back side of the lobe.
Just food for thought.
Old 12-23-2007, 09:00 AM
thanks
thanks I will live with it.
Valve Lash adjustment hiball Engine 36 05-11-2009 10:12 AM
Another ticking lifter issue.....detailed message! Zeder Engine 7 06-25-2006 08:41 PM
Hydraulic lifter question + 1.6 roller rocker 59vette Engine 2 10-27-2003 11:13 AM
solid roller cam...lifter broke! chevyelc81 Engine 7 09-05-2003 01:41 AM
STOCK VS ROLLER ROCKER ARMS?????? GONZALEZ Hotrodders' Lounge 7 06-18-2002 10:55 AM
