noisy starter - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-22-2007, 10:31 AM
noisy starter
I am having problems with my chevy 350/350 starters, I have installed two both are grinding. The casting on the first starter broke off so now I got this big inspection window. I used the paper clip trick to space the starter gear, but found that the space between the starter gear and flex plate when engaged is huge and no amount of shimming will take up the space. The flex plate looks good not bent, or chewed up.
When ever I buy a starter from summit there is only one style for the 350.
Any Ideas?
Old 08-22-2007, 04:30 PM
docvette's Avatar
Wiki Edits: 12
Any Ideas?
Doc here,
Order a SET of NEW 350 Starter bolts from GM, If you look, those are knurled..after so many changes, they no longer fit..and give the starter "Wiggle" room..
Also, If not using it, get a rear brace for the starter..
The open inspection hole will contribute to the noise level.
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Chevy 350 cracked starter mounting hole w pics skiprec Engine 14 11-11-2011 07:47 AM
Installing a mini starter on my Chevy vern kelly Electrical 5 09-09-2009 03:41 PM
small blcok chevy! The ultimate starter problem! S.O.S. sugar ray Engine 11 07-19-2007 09:07 PM
Starter questions zipfactor Engine 6 08-07-2005 08:10 AM
Carry on from other Starter POST dollybud Electrical 0 09-26-2003 06:48 PM
