noisy starter - any thoughts? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-18-2013, 10:57 AM
starter on a 64 impala. looks to be a really new one. has started making some abnormal noise on startup. tried shims - from no shim all the way until it wont engage. no shim combo kills the grinding, nasty noise. took starter off - bendix fine. teeth on flywheel fine - none missing. I did find that two of the starter bolts had come COMPLETELY out - fixed that and retourqued all of them.
i dont want to tear up the starter. the only thoughts i have are a warped flywheel or the wrong starter. any help appreciated.
Old 03-18-2013, 11:55 AM
bigdog7373's Avatar
Of course it's fast
So it's just really loud? Mine is too, i think it's just a high torque starter, idk i got it for free. But yea it's louder than seems possible. Like loud enough to hear from at least a quarter mile. So i'd say you're fine
Old 03-18-2013, 12:54 PM
this is different i think. i have a loud starter on a 66 tbird. this literally sounds like it chewing something up. sometimes it starts without the noise, but most times the noise is there. if the distributor was stabbed incorrectly or the wiring was off - could that cause enough drag to make a bunch of starter noise?
Old 03-18-2013, 03:33 PM
bigdog7373's Avatar
Of course it's fast
Sbc's came with two different flexplates with different amount of teeth. One had 153 and one had 168. A lot of starters work with both flex plates, but some only work with one or the other. So you may want to check into that. Try to find a number on it so you can identify it.
Could it be that the motor is just really tight and the starter is just straining to turn it?
Could you post a video?
Old 03-19-2013, 02:32 PM
think the mystery is solved...
called delco remy support with the tag # off the starter. its the wrong model. the right model has bolt holes that are straight across. the wrong model has bolt holes that are offset...
all i can say is i didnt do it. came that way on a trade car.
Old 03-19-2013, 02:55 PM
bigdog7373's Avatar
Of course it's fast
Glad you figured it out
Thoughts on slow start. Battery, alternator, fan, starter... V8 Super Beetle Hotrodding Basics 10 06-19-2011 04:53 PM
noisy 350 please help untchable502 Engine 25 09-03-2010 11:21 AM
noisy #8 valves tagurit Engine 7 04-28-2010 07:52 AM
Starter shifting and grinding.. new starter? Where does starter brace go? 84Z Engine 8 11-12-2007 02:44 PM
noisy starter jim 54 vette Electrical 1 08-22-2007 03:30 PM
