Been having a small problem on my 1993 S-10 Blazer. Just started doing this all of a sudden. When I first back it out in the morning and stop at my first stop sign (about 100 ft) the brakes will all of a sudden grab and lock up especially the right rear, with the smallest amount of brake pedal applied.
Before I back it out seems if I pump the brakes a few times it doesn't seem as bad or not at all. The rest of the day seems to be ok,only after it sits like overnite it does this. Haven't had time to check everything out took a quick look around tires didn't notice any fluid or leaks, my thought is could the power brake booster is going bad?,, just a thought, any ideas. Thanks.
