non-lock 3000 stall for 700r4 - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-17-2004, 05:56 PM
I was reading previous posts...I need more input.
I have a Comp Extreme cam 230/234 .490 and a 2400 b&M, 1986 700R4. I want more of a punch when I hit the pedal. Right now it don`t cut it.
I have access to a cheap converter 3000 non-lock. This car is mainly short distance driving, mostly sundays and fridays at the track.
OR
I was going to switch to a smaller duration cam (214/224 ) with my 2400 stall speed. This will be cheaper but I will lose top end.
Any opinions?
Old 03-17-2004, 06:03 PM
BOBCRMAN@aol.com's Avatar
Will the "non lock" fit your trans. The input shaft and internals are different between the lockup and non.
Old 03-17-2004, 09:41 PM
Yes.
Old 03-18-2004, 07:58 PM
airworld2's Avatar
converter question
the converter you are looking to get came from a 700 that had been set up for a clutch less converter? you need some mod's in pump to run this set up......
airworld2
