non metal window channel repair - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-11-2008, 08:24 PM
pi71's Avatar
im doing some window channel repair and the metal piece is not available. what could i use with some fiberglass webbing to form a new channel? fusor,duramix,pc11? any others ? thanks in advance
Old 11-11-2008, 09:30 PM
boatbob2
window channel......
HI,i dont understand exactly what you are trying to do. are you talking about the rubber the glass goes into? or the metal that is behind the rubber? please explain in more detail,a photo would probably get you more info.
Old 11-12-2008, 07:04 AM
pi71's Avatar
the metal channel is rotted
Old 11-12-2008, 09:27 AM
Post a photo, there is no way anyone can give you good advice without seeing exactly what you are talking about. Some rotted areas could be "filled" with something, others it would be a waste of time because it would fail very fast. Others you would have to have it repaired properly or the window won't even reinstall, we need photos. A decent close up, and one showing a larger area of where it is at.
Old 11-12-2008, 12:15 PM
Put new metal in. It's the right way.
I saw somebody fix a very rusted and weakened window channel with fiberglass matting, POR-15, and two part epoxy filler (real good stuff for restorers; strong and waterproof). They painted the window channel with POR-15, and whille it was still wet, used the POR-15 to "glue" the matting over the (many) holes. After curing, he filled it with the epoxy putty and sanded it smooth. It looked pretty good.
Old 11-12-2008, 07:50 PM
pi71's Avatar
ill get some pics as soon as i get back home, thanks
Rusted window channels firstgenbird Body - Exterior 17 10-30-2013 06:05 AM
How do I remove widsheild/rear window trim from 65 GTO without damage? smallblocker2 Body - Exterior 10 06-24-2007 11:40 PM
Dent Repair Randy Ferguson Body - Exterior 25 11-26-2005 09:00 PM
My metal finish dent repair project. beemdubya Body - Exterior 4 01-19-2005 10:51 AM
