non start 97 3.8 - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > Tech Help> Engine> Modern Electronic Engines
Old 11-17-2012, 12:38 PM
non start 97 3.8
"another" non start problem. 1997 3.8/auto. the engine turns over but the injectors won't inject ! the "Rail" is pressurized, but the injectors get no "pulse" to inject the gas. The Present owner already put in a new computer. I'm thinking of buying the car, but I don't want to Buy a Non fixable headache. I've seen posts saying" maybe it's the anti theft in the key switch", Would THAT let the car "Crank" but get no fuel, or would that just stop it from cranking ??? any Ideas Welcome Thanks
Old 11-17-2012, 01:52 PM
LATECH's Avatar
How about maybe ...... What kind of car are we talking about?
Fact is stranger than Fiction
Old 11-17-2012, 03:23 PM
Camaro
Camaro. I went to look at it. snapped a timing light on it & for some reason it started right up ! now, starts every time. I "passed" on it, ( a little "rougher" than I want). But what would cause it to not run for 3 months, then just fix itself ?
Old 11-17-2012, 03:30 PM
LATECH's Avatar
Possible bad crank sensor, or a wiring connector , either open circuit or shorted.
Could be an antitheft problem, depends on antitheft system.
Some disable cranking, some disable injector pulse or spark or both. It is designed to keep the crook busy long enough for th fuzz to show up.
Recent Modern Electronic Engines posts with photos
sbc 350 will start run rough for a few seconds die and wont start fuel-junky Engine 11 01-08-2013 11:30 AM
Lots of issues. Not sure where to start (or if I should start...) oldsevenfire Modern Electronic Engines 18 03-24-2012 01:56 PM
At first start my motor runs great (1968 Corvette 327 motor), at first start, to sscardino Hotrodding Basics 5 12-15-2011 04:06 PM
Easy cold start, hard hot start dedub Engine 34 08-13-2008 05:21 PM
change modular car will start shut off and won't start back up Ramman Engine 1 11-26-2004 08:20 PM
