non-threaded crank snout - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-08-2005, 10:58 PM
New Member
I am currently assembling a 327 SBC and discovered that the snout on the crank is not threaded and appears to have been machined that way. This has got me stumped as to how I can install a harmonic balancer so that it will be secure without a bolt and washer. Is it possible to safely press it on and will it remain secure? Or does it need to be drilled and tapped? Has anyone ran across this situation and successfully remedied it?
Old 08-08-2005, 11:10 PM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
327s had a press on balancer
Old 08-09-2005, 01:22 AM
New Member
Just drill it and tap it,the same size as a 350 cranksnout, I see our crankshaft grinder do it all the time.
He uses a 1/2" drillmotor and has someone watch and tell him if he is drilling crooked...
283/early 327's had press on balancers....another GM better idea
Old 08-09-2005, 06:27 AM
poncho62's Avatar
Wiki Edits: 5
Ever hear of one coming off?.....................didn't think so................
Old 08-09-2005, 07:05 PM
New Member
hey Punchy...
As a matter of fact, YES...I have seen a few of them come off....
but then again....building engines is my profession
Old 08-09-2005, 07:11 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
They are just press on on that engine, however as all ready suggested, I would drill and tap it and put a bolt and washer on it. If you are afraid to tackle that yourself, just get a machine shop to do it for you.
Old 08-09-2005, 08:16 PM
larryblack's Avatar
Certified Lead Foot
I have seen 1 too many come flying out.
Mr. Gasket used to make a kit that contained a drill bit, bolt and washer. It told you how deep to drill and what size tap was needed.
Most every respectible hot roder has a tap set with the correct tap or has a "FRIEND" that does.
Old 08-09-2005, 09:18 PM
Bumpstick's Avatar
Hammer and a torch
Funny... none the less that little flying balancer engine is still the most widely used power plant for performance use and every day...
BTW the engineers never intended for a SBC to spin or produce near the HP that people got out of them... Also we change things on any engine to make them survive the abuse we do to them...
Serious problems removing harmonic balancer! spyderdude Engine 55 06-09-2005 10:01 AM
350 crank with BB snout mackyLS6 Engine 3 03-15-2005 04:42 PM
bought a stroker crank... or did i??? 280zxWith305 Engine 6 02-18-2005 06:40 PM
drilling snout in crank 56don Engine 4 05-12-2003 03:56 PM
stripped crank snout gkev Engine 6 04-03-2003 03:34 PM
