Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Noob needs some guidance...
Old 08-01-2012, 01:00 PM
RWENUTS's Avatar
RWENUTS RWENUTS is online now
Sounds like the distributor is moving. Make sure you have the clamp on right that holds the dizzy down.
Set it at 12*. Test it. If it does the same thing first grab the dizzy and see if it moves. The timing will retard if it's loose causing the backfiring.
