Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Noob needs some guidance...
Old 08-01-2012, 03:30 PM
ap72 ap72 is offline
Banned
Originally Posted by 70nova327 View Post
good point on the suspect balancer, if the balancer is loose will it be noticable still on the engine? like grabbing a hub on a loose wheel bearing? or will it need to come off to see if its bad? but wether i can get it to 12 or even 3 for that matter and tightened it up and found movement on it that would be most likely be the answer wouldnt it? or am i wrong?
You're wrong.
Bring your #1 cylinder to TDC. Check your timing mark, if its not on 0 then throw the balancer away.
