normal cost to switch rearend gears - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-21-2003, 09:48 PM
the ernster's Avatar
Red face normal cost to switch rearend gears
Can anyone tell me the normal cost to change rearend gears? I want to change gear ratios from a 4:56 to 3:73 or a little higher. Don't want to get ripped off. Thanks <img src="graemlins/pain.gif" border="0" alt="[pain]" />
Old 03-22-2003, 05:25 PM
rfb92345's Avatar
Question
What kind of diff?
Old 03-22-2003, 07:49 PM
Red face
12 bolt posi <img src="graemlins/pain.gif" border="0" alt="[pain]" />
Old 03-23-2003, 07:08 AM
Post
Earnster, I have a race shop in Ga. We charge $100 plus parts to set up a rear. If they buy a complete set up kit with all bearings, shims, crush sleeve, etc. it will run about $100. The gear should cost $150-$190. You should be looking at $350-$400. If your pinion and carrier bearings can be reused it can be cheaper. This is just a ballpark figure in my area' but should give you an idea of what to expect..........Toni
Old 03-24-2003, 10:27 AM
New Member
Post
TONY: Will he have to change carriers to go from 4.56 too 3.73?
Old 03-26-2003, 02:13 AM
deuce_454's Avatar
Post
yup! you have a 4 carrier now, and you will need a 3 carrier to mount the 3.73 gears, 3.9.. somthing is the lowest you can go
