Is this normal for a turbo? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-25-2005, 10:15 PM
TNTster's Avatar
New Member
Is this normal for a turbo to be so hot that it glows?
Just wondering..
*Edit*
can any mod move this to the engine forum?
Old 02-25-2005, 10:56 PM
RCastle's Avatar
Come Home Safe Soldier
Last journal entry: Headers
They can get red hot like that. Looks as though it is on a dyno breaking in and it is probably bumped up quite a bit. It should not get like that under normal driving conditions.
Old 02-26-2005, 02:18 AM
draven's Avatar
Low on turn-signal fluid.
3 rivers.. hmm, about a 20 minute drive from me. Sure is pretty by Kaweah lake. Glad to see a local on here
Old 02-26-2005, 04:10 AM
willowbilly3's Avatar
Last journal entry: Body mods
I don't think it's unusual for an engine on a long hard pull. I've seen it a lot on roundy round cars but you only notice it at night.
Old 02-26-2005, 09:56 AM
78novaman's Avatar
The AMC, FORD, & CHEVY Guy??!!
Last wiki edit: Improving fuel economy
Last journal entry: Finally on the road
You'll even see just headers get hot on an engine if you keep it working hard on a stand. You gotta remember, there is no air flow to cool them off.
Also, stupidest thing to do is run a turbo open like it is in pic 1. Imagine a pebble (or a finger!) finding it's way in there. A spooled up turbo spins at 80,000+ RPM.
Old 02-26-2005, 05:33 PM
ChevelleSS_LS6's Avatar
Jeep XJ and a Javelin
Last wiki edit: Compression test
Last journal entry: August 9, part III
Wiki Edits: 7
"hey mr. terrorist scum insurgent guy, stick your "parts" in there."
ooh, that would probably get 'em speaking...
but seriously, wouldn't dirt get into the engine, and the turbo and kill it's lifespan by a long time? Perhaps OSHA has something on the subject regarding dyno operators.
Old 02-26-2005, 09:22 PM
coldknock's Avatar
This happens when an incorrectly sized turbocharger is used, the mixture is too lean or the timing is retared. No matter what the reason is, it's not very efficient and needs some work.
Larry
Old 02-26-2005, 11:11 PM
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
Some high end turbo engines create alot of heat on the exhaust side. I have to think that this is due to the fact that most turbos are sized too small due to the fear of lag. If a larger turbo was used, it would be easier on everything and make more power. With the larger turbo it does not take as much heat and pressure to generate the needed turbine energy to drive the compressor....so it would not get so hot.
Chris
Twin Turbo Small Block Chevy??? chevyelc81 Engine 28 10-24-2013 08:44 PM
Turbo 396 69 chevelle SS Engine 10 10-23-2013 04:00 PM
Edelbrock 1404 & turbo? BenzBoy Engine 9 02-26-2006 02:43 PM
pontiac 301 turbo gutted 87442lover Engine 10 04-30-2004 08:27 PM
Backpressure = Bad.... Right?? D M N Engine 20 01-02-2004 05:53 PM
