northstar engine for rear wheel drive - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-04-2012, 07:21 PM
Can I mate a northstar engine with a 700 r4 trans?
Old 11-05-2012, 12:44 PM
vinniekq2's Avatar
there are now kits available to change that engine to a north south position,yes
The Following User Says Thank You to vinniekq2 For This Useful Post:
69 widetrack (11-05-2012)
Old 11-05-2012, 01:51 PM
The N* bellhousing is ALMOST the same as that used on the 60 degree V6 motors. The two differences are one bolt hole needs to be moved and the top of the bellhousing needs to be modified to clear the starter (it's in the valley, under the intake). Cadillac Hot Rod Fabrications sells modified 700R4s including the correct flexplate. Alternately, get a RWD N* and matching trans out of a RWD SRX or STS, since that solves the water pump problem also.
Old 11-05-2012, 01:57 PM
Faith - Respect - Trust
I did not know that. I've always wondered why the Northstar wasn't more widely used. Even in it's front wheel drive format it would make a decent power plant for a build. I've had a few Northstars and other than the typical problem of overheating that they had occasionally, they are a strong performer. I've checked on occasion and never found any performance upgrades other than a chip that could be installed, do you know if anything performance wise is available? Do you have a URL for the north south kit available?
Thanks for the information Vinnie.
Ray
Old 11-05-2012, 02:00 PM
I need to check this out, just google "Cadillac Hot Rod Fabrications"?
Ray
Old 11-05-2012, 02:02 PM
Ray
chrfab
Old 11-05-2012, 02:03 PM
Funny thing just happened...My wife was looking over my shoulder while I was posting and said, "your not taking the engine out of my Eldorado". Women, the're so cute at this age.
Old 11-05-2012, 02:04 PM
Here's a picture of the bellhousing mods. Note the bolt on the lower right of the bellhousing that's been moved and the plate at the top to cover the starter pinion hole. Yes, they can do manual trans adaptations as well.
The Following User Says Thank You to joe_padavano For This Useful Post:
Old 11-05-2012, 03:02 PM
Thanks for these posts guys, I just spent some time at the site and I'm amazed at all the stuff available... I could never figure out why not...I guess it's because there was.
Thanks again
Ray
Gear radio on 1990 S10 4 wheel drive rear end 67mosqueda Transmission - Rearend 1 02-28-2012 09:32 AM
Front wheel drive or rear Tbucit Engine 5 10-11-2007 09:30 PM
driveshaft angle c-v joint rear wheel drive buckhorn Transmission - Rearend 4 01-13-2006 08:41 AM
Current GM rear wheel drive cars? mike 96 ws6 Hotrodders' Lounge 15 11-05-2005 04:26 PM
rear wheel drive opinianoman Transmission - Rearend 1 07-18-2003 08:32 AM
