Northstar Hot Rod - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-07-2005, 08:15 PM
Northstar Hot Rod
hi all
I hope there is a poor boy way to do this.
I have a transmission repair center in Texas and a few different customers that want help.one is a 68 camaro and the other is a 55 ford crown vic and we all want to install a northstar engine to A 700 R4. ANY HELP WILL BE NICE.
thanks ! Joe
Old 12-07-2005, 08:40 PM
hwat seems to be the problem with bolting a 700-r4 to a northstari would think it is the same bolt pattern
Old 12-07-2005, 09:07 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Welcome to Hotrodders. This forum is for introductions. If you would place your question in the Transmission forum you would have a better chance at getting answers. Enjoy the site.
Old 12-07-2005, 09:47 PM
poncho62's Avatar
Wiki Edits: 5
moving to tranny forum.
Old 12-07-2005, 09:59 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
the small 60 degree v-6 bell housing on the 700 will fit........ there is one bolt hole that must be relocated.
You cut the ear off the trans case and relocate using the engine block.
It is best to TIG weld the tranny case , I do not suggest using the MIG aluminum welders
Old 12-09-2005, 01:56 PM
Do a search for Northstar performance,
I thought I had the bookmark but don't.
There's a guy that is pretty much at the
front of the Northstar modification pack
incl hop up parts and info and I'm sure
you could at least learn something.
From what I remember reading, larger
exhaust helps (mostly just a larger
single with hi flow cats and mufflers is
what they do on the Seville's etc) and
I'm sure a higher perf chip for the computer
would give you some boost, although
that's probly $300 or so, though no doubt
cheaper than actually getting into the
motor to change cams or whatever.
Freeing up the intake tract helps too.
Esp on the 300hp versions, I seem to
remember somewhat stiffer valve springs
allow a little higher rpm range and that
isn't overly difficult or costly either.
Old 12-09-2005, 02:12 PM
http://www.chrfab.com/
Try this site
Bob
Hot rod builders wanted- Western N.C. WoodsEdge Hotrodders' Lounge 16 11-13-2013 02:47 PM
HOT ROD vs Car Craft magazine FASTCHEVY Hotrodders' Lounge 35 03-25-2008 05:11 PM
Hot Rod TV......... onebadmerc Hotrodders' Lounge 44 06-17-2006 03:57 AM
my first hot rod loco Hotrodding Basics 4 06-12-2006 05:52 AM
Google hot rod news search Jon Hotrodders' Lounge 14 02-09-2004 05:43 PM
