not 2.02 theyre 1.72 - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-11-2007, 10:47 AM
thought these heads were 2.02 they are not, but they have the 2 humps .1.72 so i can machine these out but how exspensive could this be?
i live in knoxville, tn does anybody know?or should i use my 1.94 350 heads let me know
Old 02-11-2007, 11:22 AM
1.72 ??
I don't think that the "Camel" hump heads ever had 1.72 intake valves, but only 1.94s and 2.02s--- I could be wrong, but ONCE I thought I was wrong, but found I was only mistaken...
Old 02-11-2007, 11:51 AM
backyard71nova
How 'bout posting the head casting numbers..
I don't think you have double hump heads with 1.72" intake valves..
JA
Old 02-11-2007, 12:32 PM
junior stocker's Avatar
There were some early "power pack" style heads that had 2 humps, but not the "big" humps like on the so-called "fuelie" heads. They were CANADIAN I believe and would have CANADA cast into them somewhere. Or, they could be early truck heads. Do these heads have accessory holes? Or, maybe my cerebral axions and dentrites are'nt synapsing very well anymore. BUTCH.
Old 02-11-2007, 01:11 PM
MI2600's Avatar
Member# 3287
There were NO 1.72 valve camelbacks. The power pack heads had a triangle on top of a rectangle marking, and are usually 896 or 520 castings.
Yes, what are the casting numbers.
Also, if you have 1.94" heads, I would leave them as is. I've read that the larger valves actually hinder the intake unless it is unshrouded. My machinist won't unshroud the 2.02 conversions because he says the chamber walls are too thin at that point and it will lead to cracking problems.
You should also consider what you want out of the vehicle and what the rest of the engine is.
Old 02-11-2007, 02:57 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Any old heads,
when you install
hard exhaust seats,
install larger valves,
new guides,
throat, blend, and bowl port (or more),
machine spring pockets
machne guides for seals
install rocker studs and plates,,,,
you have almost paid for a set of GOOD aftermarket heads. And the old heads still won't produce the power of new style heads.
Something about silk purses and pigs.......????
Old 02-12-2007, 12:26 AM
Here's another guess after looking at some heads on that auction site;#354434 heads that have "2 humps", 1.72 intake valves, 60cc chambers and were available 75'-79' on 262-267-305 sbc engines. Course they have mounting holes too and are light weight castings. Did I win? BUTCH.
Old 02-12-2007, 03:22 PM
casting# are 3917293 heads have 2 bars on the side of the head, the 327 is a 210 horse from a camaro with the 2 barrel intake. have it too, it's got the oil filler in the intake!! verry cool, pistons are flattop crank is cast and there appears to be no scars on the stock cyl. walls.......in christ........adam
Old 02-12-2007, 08:51 PM
DoubleVision's Avatar
3917293....67-68...307/327......75cc chambers
These aren`t double hump heads, these came on base 307/327 engines in the 60`s. There not performance heads by no means and adding bigger valves really won`t help them much since they have such a small port, these are designed for low end torque and not much else. Good thing on your engine is you can use a better set of heads, add a decent cam and timing chain along with a 4BL intake and it`ll wake up nicely. I`m soon to have my vortec heads and intake for sale, let me know if your interested.
Old 02-13-2007, 05:47 AM
Hippie's Avatar
Last journal entry: HEI comparison.
Vortecs would really wake that 327 up and your compression will be around 9.5 to 1, low enough you can still run pump gas with a fairly mild cam. Put the Comp 268HE or something similar in it and it should run pretty decent. It won't be super fast but it won't be a gutless slug either.
Old 02-13-2007, 04:35 PM
what about a magnum 270 with 373 gears and double hump heads?2.02's baby!!!!!!!!!!!!!running a performer rpm air gap too.
Old 02-13-2007, 05:16 PM
DeathRattle's Avatar
Some Punk Kid
I Have that cam(CC 270H) in a 350 with 10.5:1 compression. It shakes. It doesn't shake anymore until I get some stuff fixed on it. It wont shake your teeth out but you can't ignore it even if you tried. I like it.
Old 02-13-2007, 08:56 PM
If you find some camel humps, you`ll spend more or just as much rebuilding them that you would for a aftermarket set of heads. The hump heads are old technology. if you race someone with a equal set up as yours only they have vortec heads or aftermarket heads, your gonna get your doors blown off. Typical vortec heads make about 30 horses more, aftermarket heads make around the same amount more depending. I stopped wasteing my time on hump heads after the first time I used vortecs. I have 2 sets of hump heads I`ve been trying to sell for months that nobody seems to want, since everyone just about wants Vortecs.
Old 02-14-2007, 10:46 AM
do you have the 2.00 intake or the 1.94's. is there that much difference between them?
Old 02-17-2007, 07:12 AM
anybody home?
1.94 heads or 2.02 jeff germano Engine 10 05-23-2013 05:38 PM
1.94 vs 2.02 fbodyfreak Engine 8 02-03-2007 02:29 PM
Are These 2.02 Heads ??????? STATUTORY GRAPE Engine 2 05-10-2004 09:29 AM
434 chevy heads cutout to 2.02 jrtraveler79 Engine 3 02-29-2004 10:25 AM
2.02 valves on stock 302 pistons mustang66maniac Engine 3 08-06-2002 11:30 AM
