Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - not bright
Thread: not bright
Old 10-20-2002, 08:24 AM
Kevin45's Avatar
Kevin45 Kevin45 is offline
Just one of the guys
Last journal entry: Vise jaws
Post
Run a temporary ground from the tailight socket to a good ground on the frame. Make sure it is clean bare metal then see what you got. If they do brighten up then you will have to run a permanent ground because you have a broke wire somewhere in the harness or you are not grounding good from the tailight assembly to the body.
Kevin
