Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Not enough base under clear coat!
Old 11-22-2007, 04:21 AM
kenseth17 kenseth17 is offline
I agree with milo, if there is an area that is convienient to mask off for a blend or if you feel you can just paint the bottom, I'd do a blend if you feel you can get a good looking repair, and save on paint and effort. Being under the car, really not going to be exposed to uv. I painted a motorcycle frame once and even though fairly small, don't want to go through that any time soon, all the areas and nooks and crannys to hit. Also had to seal a semi frame and seal and paint a trailer frame that had been blasted inside of the rails in the past at jobs, wasn't having a ball on either of em, I can feel your pain and understand how a spot could be missed.
